Hallo, ebend Mails gecheckt und ne Info bekommen.
Endlich sind sie da. Die Flat Boxen von Hertz
Erhältlich mit einem 8" oder einem 10" Lautsprecher. Beide haben zusätzlich eine Passiv Membrane.
1. ULTRA Flat profile, keeping size to a minimum for ease of placement and hidden
cosmetic integration within the vehicle.
2. Constructed from 18 mm MDF with internal bracing, minimizing enclosure losses.
3. Slanted lower panel helps to reduce back wave reflections and eases installation.
4. Low loss foam surround Passive Radiator, for powerful, undistorted output.
5. Low profile-high excursion subwoofer unit provides bursting dynamics.
6. Molded metal grille offers total speaker protection and great cosmetic appeal.
7. Reversible Hertz Logo, configurable to the different installation positions.
8. Proprietary connection terminals provides the utmost in functionality and safety.
9. Easy-Remove metal mounting system, for a clean and reliable installation.
SUB-BOX Reflex 200mm 4 Ohm
Component Passive Radiator Reflex Sub Box
Speaker Size mm (inch) 200 (8”)
Passive Radiator Size mm (inch) 250 (10”)
Power Handling W peak 400
W continuous 200
Impedance Ω 4
Frequency Response Hz 40 ÷ 400
Sensitivity dB/SPL 90
Box Size W 520 (20” 1/2)
mm (inch) D 108 (4” 1/4)
H 320 (12” 5/8)
Magnet High density
flux ferrite
Cone Water-repellent
pressed paper
Weight kg (lb) 7,2 (15,87)
UVP: 199.- Für Forum User 180.-
EBX F25.5 - SUB-BOX Reflex 250mm 4 Ohm
Speaker Size mm (inch) 250 (10”)
Passive Radiator Size mm (inch) 300 (12”)
Power Handling W peak 600
W continuous 300
Impedance Ω 4
Frequency Response Hz 38 ÷ 350
Sensitivity dB/SPL 92
Box Size W 670 (26” 3/8)
mm (inch) D 119 (4” 11/16)
H 403 (15” 7/8)
Magnet High density
flux ferrite
pressed paper
Weight kg (lb) 11,9 (26,24)
UVP: 269.- Forum Preis 250.-
Die Treiber sind auch einzeln erhältlich für Leute die lieber selber ne Kiste Bauen.
